[Gdal-dev] missing/wrong compiler option in nmake.opt
Frank Warmerdam fwarmerdam at gmail.com
Tue Mar 1 12:17:32 EST 2005
On Tue, 1 Mar 2005 11:01:03 -0500, Stephane Routelous <route at cae.com> wrote:
> Hi,
> the flag /MDd (Debug Multithread Dll) is missing in the OPTFLAGS for the
> debug version in nmake.opt to compile on windows with VisualC++ for 1.25
> in the daily build (20050301.zip) the flag should be /MDd and not /MD
Stephane,
When I build debug versions of GDAL I always use the non-debug
runtime library to avoid various complexities.  I realize that others may
not want to do this and will want to use /MDd, which is fine, but I
have set things up the way they are on purpose.
Best regards,
