[Gdal-dev] Problems with creating PNG files
Roger James
roger at beardandsandals.co.uk
Tue Mar 1 13:26:43 EST 2005
Frank,
You got it in one. I was just double clicking and letting the default
windows picture and fax viewer open it. I have just tried opening the files
in Photoshop and they look fine!
I will see if I can get libpng-1.2.8 to build and see if that fixes it.
Roger
> Roger,
> The file looks fine with me. However, folks have encountered
> problems reading png files produced with modern libpng versions
> using the built-in windows support for png. What are you using to
> check the png files?
> If this is the problem, you will likely need to downgrade to an
> older libpng to retain compatibility with windows. I don't understand
> what change caused this .. I have just seen the result.
> If this turns out to be the issue for you as well, I would appreciate
> your summizing back to the list as a warning to others.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
