[Gdal-dev] building GDAL in Visual C++ Toolkit 2003
bartvde at xs4all.nl
Fri Mar 4 12:14:44 EST 2005
Hi list,
I tried to compile GDAL using the free Visual C++ Toolkit 2003 in
combination with the Microsoft Platform SDK, and the .NET Framework SDK.
I ran into the following problem:
C:\projects\gdal-1.2.5\frmts\gtiff\libtiff\tiffio.h
tiffio.h uses <iostream.h> which is deprecated, I had to change it into
the following:
#if defined(c_plusplus) || defined(__cplusplus)
# include <iostream>
extern TIFF* TIFFStreamOpen(const char*, std::ostream *);
extern TIFF* TIFFStreamOpen(const char*, std::istream *);
#endif
Is there any reason not to use this in the standard GDAL distribution?
Best regards.
Bart
