[Gdal-dev] GDAL hanging on TIFF operation?
Frank Warmerdam fwarmerdam at gmail.com
Fri Mar 4 11:03:31 EST 2005
On Fri, 4 Mar 2005 10:49:21 -0500, Ed McNierney <ed at topozone.com> wrote:
> Folks -
> I'm a little puzzled by what seems a straightforward operation on
> "ordinary" GeoTIFF images (some collar-clipped USGS DRG files).
> I'm doing some performance testing on a set of 8-bit GeoTIFFs and I'm
> using gdalwarp to convert to different formats/organizations.  But I
> cannot figure out what's going on.  The files are correctly read by GDAL
> as part of MapServer, but when I use the GDAL command-line utilities
> gdalwarp and gdalinfo, they hang.
Ed,
Sorry, I don't see any obvious reason for a problem.  I will note that
output to compressed TIFF from gdalwarp is not currently working.
It is possible the problem could manifest as a hang, though I haven't
seen that.
If you can provide me with a file, and a commandline to reproduce the
problem I would be happy to look into it.
Best regards,
