[Gdal-dev] GDAL hanging on TIFF operation?
Ed McNierney
ed at topozone.com
Fri Mar 4 10:49:21 EST 2005
Folks -
I'm a little puzzled by what seems a straightforward operation on
"ordinary" GeoTIFF images (some collar-clipped USGS DRG files).
I'm doing some performance testing on a set of 8-bit GeoTIFFs and I'm
using gdalwarp to convert to different formats/organizations. But I
cannot figure out what's going on. The files are correctly read by GDAL
as part of MapServer, but when I use the GDAL command-line utilities
gdalwarp and gdalinfo, they hang.
I've tried this with GDAL 1.2.5 and with the 1.2.6b3 code with the same
results. I have no trouble with tiffinfo and listgeo (I'm building with
the external tiff and geotiff libraries) so I do not expect there's
anything wrong with those supporting libraries. I get a few warning
messages (see below) that seem to be either expected (tiffinfo) or
chronic and harmless (incorrect count for field "DateTime").
The source files are 8-bit GeoTIFFs with LZW compression, organized as
one row/strip. The tiffinfo and listgeo output is below - any ideas
would be appreciated. Thanks!
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
# tiffinfo O40100H8.tif
O40100H8.tif: Warning, incorrect count for field "DateTime" (23,
expecting 20); tag ignored.
TIFFReadDirectory: Warning, O40100H8.tif: unknown field with tag 33550
(0x830e) encountered.
TIFFReadDirectory: Warning, O40100H8.tif: unknown field with tag 33922
(0x8482) encountered.
TIFFReadDirectory: Warning, O40100H8.tif: unknown field with tag 34735
(0x87af) encountered.
TIFFReadDirectory: Warning, O40100H8.tif: unknown field with tag 34737
(0x87b1) encountered.
TIFF Directory at offset 0x20b9fa
Subfile Type: multi-page document (2 = 0x2)
Image Width: 4442 Image Length: 5786
Resolution: 250, 250 pixels/inch
Bits/Sample: 8
Compression Scheme: LZW
Photometric Interpretation: palette color (RGB from colormap)
Image Description: "USGS GeoTIFF DRG 1:24000 Quad of Dickens NW."
Orientation: row 0 top, col 0 lhs
Samples/Pixel: 1
Rows/Strip: 1
Planar Configuration: single image plane
Page Number: 0-1
Color Map: (present)
Software: TopoZone DRG Processing 1.1
Tag 33550: 2.438400,2.438400,0.000000
Tag 33922:
0.500000,0.500000,0.000000,331436.203920,4540683.787793,0.000000
Tag 34735:
1,1,0,4,1024,0,1,1,1025,0,1,1,3072,0,1,26914,3073,-30799,25,0
Tag 34737: UTM Zone 14 N with NAD83|
# listgeo O40100H8.tif
Geotiff_Information:
Version: 1
Key_Revision: 1.0
Tagged_Information:
ModelTiepointTag (2,3):
0.5 0.5 0
331436.204 4540683.79 0
ModelPixelScaleTag (1,3):
2.4384 2.4384 0
End_Of_Tags.
Keyed_Information:
GTModelTypeGeoKey (Short,1): ModelTypeProjected
GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
ProjectedCSTypeGeoKey (Short,1): PCS_NAD83_UTM_zone_14N
PCSCitationGeoKey (Ascii,25): "UTM Zone 14 N with NAD83"
End_Of_Keys.
End_Of_Geotiff.
PCS = 26914 (NAD83 / UTM zone 14N)
Projection = 16014 (UTM zone 14N)
Projection Method: CT_TransverseMercator
ProjNatOriginLatGeoKey: 0.000000 ( 0d 0' 0.00"N)
ProjNatOriginLongGeoKey: -99.000000 ( 99d 0' 0.00"W)
ProjScaleAtNatOriginGeoKey: 0.999600
ProjFalseEastingGeoKey: 500000.000000 m
ProjFalseNorthingGeoKey: 0.000000 m
GCS: 4269/NAD83
Datum: 6269/North American Datum 1983
Ellipsoid: 7019/GRS 1980 (6378137.00,6356752.31)
Prime Meridian: 8901/Greenwich (0.000000/ 0d 0' 0.00"E)
Projection Linear Units: 9001/metre (1.000000m)
Corner Coordinates:
Upper Left ( 331434.985, 4540685.007)
Lower Left ( 331434.985, 4526576.425)
Upper Right ( 342266.358, 4540685.007)
Lower Right ( 342266.358, 4526576.425)
Center ( 336850.671, 4533630.716)
