[Gdal-dev] MEM -- In Memory Raster Datasets
Frank Warmerdam
fwarmerdam at gmail.com
Tue Mar 8 11:32:22 EST 2005
On Tue, 08 Mar 2005 11:57:35 +0100, Reiner Beck <r.beck at m4com.de> wrote:
> Hello List,
> playing around with the In Memory Raster datasets I found a few issues:
> - The example in the documentation reads "MEM::DATAPOINTER...", it
> should be "MEM:::DATAPOINTER...". One additional colon.
Reiner,
Fixed.
> - DATATYPE keyword: The documentation states "Name of the data type, as
> returned by GDALGetDataTypeName() (eg. Byte, Int16)". This does not
> work. In "frmts/mem/memdataset.cpp" the integer value of the enumeration
> "GDALDataType" is used (i.e. "1" for Byte).
I have fixed it so the name *or* the numeric values work.
> - The constructor "MEMDataset::Open(...)" seems to leak the papszOptions
> as returned by "CSLTokenizeStringComplex()". It is not free'd in case of
> success with "CSLDestroy( papszOptions )".
Fixed.
I have also written a minimist mem.py test script for the mem driver.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
