[Gdal-dev] Re: Large file support on MacOS X
Jed O. Kaplan jed.kaplan at jrc.it
Thu Mar 17 10:48:50 EST 2005
Hello,
I am using gdal 1.2.6 from CVS on Mac OS X (10.3).
I recently saw the discussion on large files on Gdal-dev and am having
similar problems, trying to use gdal_translate to convert a ~15Gb
raster file in Erdas large file format (.img+.ige) to another format.
The gdal_translate fails about 10% into the job with the following
error:
ERROR 3: Seek to 80000cad:80000cad on 0xa0009920 failed
invalid argument
ERROR 1: IReadBlock failed at X offset 990, Y offset 217
ERROR 1: GetBlockRef failed at X block offset 990, Y block offset 217
Has anyone managed to solve large file support for GDAL on MacOS X?
Thanks for your help.
Cheers,
Jed Kaplan
> [Gdal-dev] Large file support on MacOS X
> Jonathan Greenberg  usenet at estarcion.net
>  Mon Jan 24 11:20:13 EST 2005
> 	• 	Previous message: [Gdal-dev] Fwd: Warning again
> 	• 	 Next message: [Gdal-dev] Large file support on MacOS X
> 	• 	 Messages sorted by:  [ date ]  [ thread ]  [ subject ]  [ author ]
> Has anyone tried to get GDAL compiled under MacOS X and have it work
> for
> large (> 4gb) files?  If so, what flags do I need to add to the
> compiler to
> get it to work?
> --j
