[Gdal-dev] WGS84 to NAD27 failed to load NAD27-83 correction file
Frank Warmerdam
fwarmerdam at gmail.com
Wed Mar 23 11:27:48 EST 2005
On Wed, 23 Mar 2005 09:13:35 -0700, Sheykhet, Rostic <rsheykhet at sanz.com> wrote:
> Frank,
> Thanks for your response. I have recompiled proj4 (and gdal 1.2.6 just
> in case) with the change. I am still getting exact same error,
> though... Any pointers are appreciated.
Rostic,
Do you have the null file? It was not distributed (or improperly
formatted or something) at one time. I am attaching a binary
version suitable to drop into /usr/local/share/proj on little
endian systems gcc based systems (ie. linux).
If you need it for windows or some other system let me know.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050323/987bbf2d/null.obj
