[Gdal-dev] tif + .tfw + Proj4 projection information => Fully
Referenced GeoTiff
Rich Signell
rsignell at usgs.gov
Wed May 18 15:27:16 EDT 2005
I'm hoping someone will take pity on a newbie here.
I've got a bunch of .tif images, corresponding .twf files, and I've also been
told that all the .tifs are in meters, Mercator w/ standard parallel of 41.65
and a central meridian of -70.316667, NAD83 datum.
I'd like to convert these to EPSG:4326, which would be easy to do using
gdalwarp, except that I need a fully georeferenced geotiff as input, right?
So then I need a tool to add the georeferencing info.
I tried using OpenEV, but it looks like it also wants a properly georeferenced
file to begin with.
It looks like I could also use "geotifcp", but it seems that I would need to
find a properly reference geotiff first in my projection so that I could use
"listgeo" to understand the input projection text file format.
After this, I had a sneaking suspicion that I was overlooking something. There
is an easy way, right?
Thanks,
Rich
Richard P. Signell
U.S. Geological Survey Phone: (508) 457-2229
384 Woods Hole Road Fax: (508) 457-2310
Woods Hole, MA 02543-1598
