[Gdal-dev] Problem with Lambert Conformal Conic projection.
Julien Demaria
dem at acri-st.fr
Mon May 23 07:05:27 EDT 2005
When I use gdal_translate with a Lambert Conformal Conic projection,
ProjFalseEastingGeokey and ProjFalseNorthingGeokey are not copied.
>gdalinfo lambert93.tif
Driver: GTiff/GeoTIFF
Size is 1, 1
Coordinate System is:
PROJCS[,
GEOGCS["IMAGINE GeoTIFF Support
Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
@(#)$RCSfile: gtiff_io.c,v $ $Revision: 1.13 $ $Date: 2004/07/15 15:11:38 $
Unable to match Ellipsoid (Datum) to a Geo",
DATUM["unknown",
SPHEROID["GRS 1980",6378137,298.2572221010042,
AUTHORITY["EPSG","7019"]]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",44],
PARAMETER["standard_parallel_2",49],
PARAMETER["latitude_of_origin",46.5],
PARAMETER["central_meridian",3],
PARAMETER["false_easting",700000],
PARAMETER["false_northing",6600000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (737240.360000,6824856.720000)
Pixel Size = (0.68000000,-0.68000000)
Metadata:
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Corner Coordinates:
Upper Left ( 737240.360, 6824856.720) ( 3d30'15.54"E, 48d31'22.37"N)
Lower Left ( 737240.360, 6824856.040) ( 3d30'15.54"E, 48d31'22.35"N)
Upper Right ( 737241.040, 6824856.720) ( 3d30'15.58"E, 48d31'22.37"N)
Lower Right ( 737241.040, 6824856.040) ( 3d30'15.58"E, 48d31'22.35"N)
Center ( 737240.700, 6824856.380) ( 3d30'15.56"E, 48d31'22.36"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
>gdal_translate lambert93.tif translate_lambert93.tif
>gdalinfo translate_lambert93.tif
Size is 1, 1
PROJCS[,
DATUM["unknown",
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
Metadata:
Corner Coordinates:
Upper Left ( 737240.360, 6824856.720) (169d16'18.53"W, 85d50'22.87"N)
Lower Left ( 737240.360, 6824856.040) (169d16'18.66"W, 85d50'22.88"N)
Upper Right ( 737241.040, 6824856.720) (169d16'18.66"W, 85d50'22.87"N)
Lower Right ( 737241.040, 6824856.040) (169d16'18.79"W, 85d50'22.88"N)
Center ( 737240.700, 6824856.380) (169d16'18.66"W, 85d50'22.87"N)
Band 1 Block=1x1 Type=Byte, ColorInterp=Red
Band 2 Block=1x1 Type=Byte, ColorInterp=Green
Band 3 Block=1x1 Type=Byte, ColorInterp=Blue
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050523/9af914e6/lambert93.tif.obj
