[Gdal-dev] Problem with Lambert Conformal Conic projection.
Frank Warmerdam
fwarmerdam at gmail.com
Mon May 23 11:31:53 EDT 2005
On 5/23/05, Julien Demaria <dem at acri-st.fr> wrote:
> Hi,
> When I use gdal_translate with a Lambert Conformal Conic projection,
> ProjFalseEastingGeokey and ProjFalseNorthingGeokey are not copied.
Julien,
I tried your example with GDAL CVS and the false easting and northing
were not lost. Are you using 1.2.6? On what platform? I don't
*recall* fixing something like this recently, but I have a terrible memory
so it is possible it was fixed since 1.2.6 was released.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
