[Gdal-dev] Problem with Lambert Conformal Conic projection.
Tyler Mitchell tylermitchell at shaw.ca
Mon May 23 09:51:56 EDT 2005
> When I use gdal_translate with a Lambert Conformal Conic projection,
> ProjFalseEastingGeokey and ProjFalseNorthingGeokey are not copied.
I'm not sure why, but I wonder if it is related to the image being only size = 1,1.  Have you tried this on a larger image?
Tyler
Gdal-dev mailing list
Gdal-dev at xserve.flids.com
http://xserve.flids.com/mailman/listinfo/gdal-dev
