[Gdal-dev] Problem with Lambert Conformal Conic projection.
Julien Demaria
dem at acri-st.fr
Mon May 23 10:05:53 EDT 2005
Tyler,
All my tests was on a standard image larger than 1x1, but I create this
small image because there is a size limit of attachments on the mailing list.
Regards,
Julien
At 15:51 23/05/2005, Tyler Mitchell wrote:
> > When I use gdal_translate with a Lambert Conformal Conic projection,
> > ProjFalseEastingGeokey and ProjFalseNorthingGeokey are not copied.
>I'm not sure why, but I wonder if it is related to the image being only
>size = 1,1. Have you tried this on a larger image?
>Tyler
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at xserve.flids.com
>http://xserve.flids.com/mailman/listinfo/gdal-dev
