[Gdal-dev] Proposed MrSid RasterIO() patch
Sheykhet, Rostic
rsheykhet at sanz.com
Mon Nov 7 12:54:43 EST 2005
Hi All/Frank,
I think I've managed to track down the issue below. It looks like
the code was asking for a larger image chunk that was available at a
particular zoom level. I am attaching a suggested patch. I have tested
it on my system and it seems to work. Instead of guessing what the
dimensions are at a particular zoom level by doing a division, the patch
code explicitly queries the LizardTech driver for the overview
dimensions and uses those to work out the scene of interest.
Thanks
Rostic
>> From: gdal-dev-bounces at lists.maptools.org
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Sheykhet,
Rostic
>> Sent: Thursday, October 20, 2005 11:29 AM
>> To: Frank Warmerdam
>> Cc: gdal-dev at lists.maptools.org
>> Subject: RE: [Gdal-dev] JP2MrSID internal overviews problem
>> Hi Frank,
>> The previous issue has gone away, but a slightly different problem
still
>> occurs:
>> MrSIDRasterBand::IRasterIO(): Failed to load image.
>> specified scene out of range of image [50014] >>
>> GDAL Overview Band information from the debugger:
>> nBand 1 int
>> nRasterXSize 94 int
>> nRasterYSize 75 int
>> eDataType GDT_Byte GDALDataType
>> eAccess GA_ReadOnly GDALAccess
>> nBlockXSize 94 int
>> nBlockYSize 75 int
>> nBlocksPerRow 0 int
>> nBlocksPerColumn 0 int
>> bSubBlockingActive 0 int
>> nSubBlocksPerRow 0 int
>> nSubBlocksPerColumn 0 int
>> + papoBlocks 0x00000000 GDALRasterBlock * *
>> nBlockReads 0 int
>> bForceCachedIO 0 int
>> Again, I am accessing an overview directly and issuing a >>
RasterIO(GF_Read,0,0,94,75,buffer,119,95,GDT_Byte,0,0).
>> I would guess that the things of interest are
>> a) I am requesting the full extent of overview
>> b) I am requesting a scaled version of the image
>> Thank you for your help.
>> Rostic
Type: application/octet-stream
Desc: mrsiddataset.patch
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051107/a1536536/mrsiddataset.obj
