[Gdal-dev] hdf5 and gdal
Frank Warmerdam
warmerdam at pobox.com
Thu Nov 10 10:59:50 EST 2005
On 11/10/05, blaž kurnik <blazkurnik at gmail.com> wrote:
> Dear Developers and others
> I have a problem how to read hdf5 in grass6 using gdal 1.3.1
> I wrote
> r.in.gdal -o input=HDF5:"sat.h5":TemperaturePrecision output=aa
> where sat.h5 is hdf5 file and TemperaturePrecision is dataset
> Massage of the error is :
> szFilenname sat.h5
> Segmentation fault
> The same error is when i use gdal_translate as
> gdal_translate -sds -of AAIGrid -co "TILED=YES" HIRPROF_v582v2.he5
> sat.ascii
Blaz,
Could you file a bug in bugzilla on this, including information
on how to get HIRPROF_v582v2.he5?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
