[Gdal-dev] RE: Reading JPEG2000 JPC and J2K
Chapman, Martin MChapman at sanz.com
Fri Nov 11 13:05:25 EST 2005
Gao,
You can use the MrSID driver, Kakadu or Jasper.  I would recommend
MrSID.  You need to download the MrSID DSDK from Lizardtech for reading
and you need to get the ESDK for read/write.  To get the ESDK you will
have to go through the clearance process first I believe.  The MrSID
driver reads J2k and MrSID.  ECW can also read the new jpeg formats but
I don't know if that is enabled through GDAL yet.
Martin
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Peng Gao
Sent: Friday, November 11, 2005 7:48 AM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] RE: Reading JPEG2000 JPC and J2K
> From: Peng Gao
> Sent: Friday, November 11, 2005 6:30 AM
> Subject: Reading JPEG2000 JPC and J2K
> I got some images with .jpc and .j2k extensions. Is there any
> way I can read them using GDAL?
> I renamed them to .jp2, and it didn't work. I am using Kakadu codec.
> Gao, Peng
I read the doc on JP2KAK driver again, and it should support JPC. The
problem could be the image I have. Attached is a problem jpc image.
Gao, Peng
