[Gdal-dev] Reading JPEG2000 JPC and J2K
Tom Lynch
tflynch at gmail.com
Sun Nov 13 19:54:18 EST 2005
On 11/12/05, Chapman, Martin <MChapman at sanz.com> wrote:
> You can use the MrSID driver, Kakadu or Jasper. I would recommend
> MrSID. You need to download the MrSID DSDK from Lizardtech for reading
> and you need to get the ESDK for read/write. To get the ESDK you will
> have to go through the clearance process first I believe. The MrSID
> driver reads J2k and MrSID. ECW can also read the new jpeg formats but
> I don't know if that is enabled through GDAL yet.
Gao,
The GDAL JP2ECW driver based on the ECW JPEG 2000 SDK should also read
raw jpc, j2k codestreams automatically - e.g. result of gdalinfo on
some of the conformance data:
Driver: JP2ECW/ERMapper JPEG2000
Size is 128, 128
Coordinate System is `'
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 128.0)
Upper Right ( 128.0, 0.0)
Lower Right ( 128.0, 128.0)
Center ( 64.0, 64.0)
Band 1 Block=128x1 Type=Byte, ColorInterp=Undefined
Overviews: arbitrary
Hope this helps.
Tom Lynch
Development, ER Mapper
Phone: +61 8 93882900
Fax: +61 8 93882901
Email: tom.lynch at ermapper.com
Web: http://www.ermapper.com
Forums: http://forum.ermapper.com
