[Gdal-dev] Oracle-bindings
Stephan Holl sholl at gmx.net
Wed Nov 16 10:25:04 EST 2005
Hello Bart,
On Wed, 16 Nov 2005 15:37:07 +0100 "Bart van den Eijnden"
<BEN at Syncera-ITSolutions.NL> wrote:
> Are you able to connect with sqlplus?
Yes, using the instant.client packages which I recently installed.
holl at bim:~/instantclient10_1 > ./sqlplus holl at ORACLESP
SQL*Plus: Release 10.1.0.4.0 - Production on Wed Nov 16 16:13:39 2005
Copyright (c) 1982, 2005, Oracle.  All rights reserved.
Enter password:
Connected to:
Oracle Database 10g Enterprise Edition Release 10.1.0.3.0 - Production
With the Partitioning, OLAP and Data Mining options
SQL> quit
Disconnected from Oracle Database 10g Enterprise Edition Release
10.1.0.3.0 - Production With the Partitioning, OLAP and Data Mining
options holl at bim:~/instantclient10_1 >
So OGR should work the same, but actually it does not....
mhhh.
Best regards,
	Stephan
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051116/d7092867/signature.bin
