[Gdal-dev] problem merging 1 second data with gdal_merge.py
Frank Warmerdam
warmerdam at pobox.com
Wed Nov 16 11:51:52 EST 2005
On 11/16/05, Rich Signell <rsignell at usgs.gov> wrote:
> So I made requests for two blocks with ranges
> [-75.0 -74.5] [43.5 44.0]
> [-74.5 -74.0] [43.5 44.0]
> and requested each image block to be 1800 x 1800 points (since
> this DEM data is Area based).
Rich,
Could you make the two tiles available for me to grab, so I
can try this out? I suspect it is a roundoff issue in gdal_merge.py.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
