[Gdal-dev] problem merging 1 second data with gdal_merge.py
Rich Signell
rsignell at usgs.gov
Wed Nov 16 11:13:18 EST 2005
Gdal-folk,
I'm having trouble using gday_merge.py to merge blocks of 1 sec
data obtained as Geotiff from a WMS server.
I have a 1 degree x 0.5 degree region
lon=[-75.0 -74.0], lat=[43.5 44.0] that I want to cover, but
unfortunately that's too much for the WMS to handle.
So I made requests for two blocks with ranges
[-75.0 -74.5] [43.5 44.0]
[-74.5 -74.0] [43.5 44.0]
and requested each image block to be 1800 x 1800 points (since
this DEM data is Area based).
I check each .tif with gdalinfo, and everything looks good:
$gdalinfo ad01.tif
Driver: GTiff/GeoTIFF
Size is 1800, 1800
Pixel Size = (0.00027778,-0.00027778)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=SGI's Image Format Library/1.2
Corner Coordinates:
Upper Left ( -75.0000000, 44.0000000)
Lower Left ( -75.0000000, 43.5000000)
Upper Right ( -74.5000000, 44.0000000)
Lower Right ( -74.5000000, 43.5000000)
Band 1 Block=1800x1 Type=Float32, ColorInterp=Gray
$gdalinfo ad02.tif
Upper Left ( -74.5000000, 44.0000000)
Lower Left ( -74.5000000, 43.5000000)
Upper Right ( -74.0000000, 44.0000000)
Lower Right ( -74.0000000, 43.5000000)
But when I merge them:
$gdal_merge.py -o merged.tif ad01.tif ad02.tif
I get:
$gdal_info merged.tif
Size is 3599, 1800
Origin = (-75.000000,44.000000)
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Right ( -74.0002778, 44.0000000)
Lower Right ( -74.0002778, 43.5000000)
Band 1 Block=3599x1 Type=Float32, ColorInterp=Gray
So the resulting tif is NOT 3600x1800, but 3599x1800, and the
limits are now 1 pixel smaller in the merged direction (do not
extend to -74 as did the original).
Is this a "area" vs. "point" registration problem in the
gdal_merge.py logic, or (more likely) have I made some silly mistake?
Thanks,
Rich
Richard P. Signell
U.S. Geological Survey Phone: (508) 457-2229
384 Woods Hole Road Fax: (508) 457-2310
Woods Hole, MA 02543-1598
