[Gdal-dev] Gdal compilation problems in Solaris 8
Juan Mari Celihueta jmcm at euskalnet.net
Fri Nov 18 07:02:27 EST 2005
Hi Frank,
I did what you told me and te 'make' compilation process was well.
Then I entered as root and did the instalation process:
# make install
And after a few seconds the process stopped, getting the next set of
error messages:
GNUmakefile:44: warning: overriding commands for target `libgdal.la'
GNUmakefile:40: warning: ignoring old commands for target `libgdal.la'
make[2]: swig: Command not found
make[2]: *** [gdal_wrap.cpp] Error 127
/bin/sh: syntax error at line 1: `;' unexpected
make[1]: *** [install] Error 2
make: *** [install-actions] Error 2
I guess that it's because of the lack of the 'swig' compilation.
Best regards,
Juan.
I set the wheels in motion
turn up all the machines
activate the programs
and run behind the scene
Rush
(I'm also a Rush fan :-D )
Frank Warmerdam escribió:
>On 11/17/05, Juan Mari Celihueta <jmcm at euskalnet.net> wrote:
>>(cd swig; make build)
>>make[1]: Entering directory `/home1/MAPSERVER/SRC/gdal-1.3.1/swig'
>>for dir in ; do (cd $dir; make build ); done
>>make[1]: *** [build] Error 2
>>make[1]: Leaving directory `/home1/MAPSERVER/SRC/gdal-1.3.1/swig'
>>make: *** [swig-target] Error 2
>Juan,
>This is a problem with using /bin/sh instead of /bin/bash, well
>really I should say the problem is that a "bashism" slipped into the
>makefile.
>To work around this manually edit gdal/GNUmakefile and change:
>swig-target:
>	(cd swig; $(MAKE) build)
>to:
>swig-target:
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
