[Gdal-dev] Gdal compilation problems in Solaris 8
Juan Mari Celihueta jmcm at euskalnet.net
Fri Nov 18 12:07:48 EST 2005
Hi Frank,
Thank you for the answer. I guessed it and I have deleted all the lines
related with 'cd swig' in the GNUmakefile, and finally the compilation
and installation under Solaris 8 was ok. Anyway it would be great if the
next version had solved this problems.
Many thanks and best regards.
Juan M.
Frank Warmerdam escribió:
>On 11/18/05, Juan Mari Celihueta <jmcm at euskalnet.net> wrote:
>>Hi Frank,
>>I did what you told me and te 'make' compilation process was well.
>>Then I entered as root and did the instalation process:
>># make install
>>And after a few seconds the process stopped, getting the next set of
>>error messages:
>>GNUmakefile:44: warning: overriding commands for target `libgdal.la'
>>GNUmakefile:40: warning: ignoring old commands for target `libgdal.la'
>>make[2]: swig: Command not found
>>make[2]: *** [gdal_wrap.cpp] Error 127
>>/bin/sh: syntax error at line 1: `;' unexpected
>>make[1]: *** [install] Error 2
>>make: *** [install-actions] Error 2
>>I guess that it's because of the lack of the 'swig' compilation.
>Juan,
>Sorry about this.  If you search through the GNUmakefile,
>you should find a target called "install-actions".  One of the
>lines after it will be "(cd swig; $(MAKE) install)".  Just
>delete that line.
>I think I'm going to have to issue a GDAL 1.3.2 pretty soon
>so not too many others run into this problem.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
