[Gdal-dev] grass-driver conflicts with gtk+?
Frank Warmerdam
warmerdam at pobox.com
Thu Oct 6 09:31:23 EDT 2005
On 10/6/05, Ari Jolma <ari.jolma at tkk.fi> wrote:
> Hi,
> If I compile and use 1.3.1 with grass (I've got 6.0.1) and then use that
> libgdal with my own code, which uses gtk+ I get a segfault when I open a
> File Open dialogbox. Without the grass driver there are no problems.
> Below is stack trace. Any ideas? Threads seem to be involved somehow. I
> removed and tried to use the stand-alone gdal-grass but don't have time
> now to look into how it is used (should it autoload somehow?)
Ari,
I am not aware of any conflict.
However, it seems quite possible that there might be some conflicting
symbols between the Gtk libraries and GRASS especially because they
both have the habit of prefixing stuff with g_ to make them "unique".
I am not sure how one would go about isolating such a problem.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
