[Gdal-dev] Having problems with gdaladdo
Steven Bowden
steveb at bundaberg.qld.gov.au
Thu Oct 13 18:32:06 EDT 2005
Hi List,
I am relatively new to using gdal to process my orthophotos. I am using
mapserver to publish the orthos in a web app.
I am trying to use gdaladdo to create the overviews for the tif files but I am
getting some strange results in the tif files after I have created the
overviews. The second last overview is corrupted and the last/smallest
overview always has a yellow square in the bottom right right hand corner of
the image.
I am using gdal 1.3.1 and gd 2.0.33.
The source tif files that I am using are uncompressed non-GeoTiff files so I
have created a .wld file so that gdal can create a geotiff.
Here is the gdal-info results for the source file:
Driver: GTiff/GeoTIFF
Size is 1436, 3083
Coordinate System is `'
Origin = (428440.494370,7242335.759860)
Pixel Size = (0.15000000,-0.15000000)
Corner Coordinates:
Upper Left ( 428440.494, 7242335.760)
Lower Left ( 428440.494, 7241873.310)
Upper Right ( 428655.894, 7242335.760)
Lower Right ( 428655.894, 7241873.310)
Center ( 428548.194, 7242104.535)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
We also use a commercial GIS product called GenaMap and here is what it
reports on the source image:
Image name : img27-2.tif
Format : tiff
Size : 1436 x 3083
Depth : 8 (unsigned)
Bands : 3 (bip layout)
Storage : tiles of 256 x 256
Compression : none
I then run the following gdal commands:
gdal_translate -of GTiff -a_srs EPSG:28356 -co "INTERLEAVE=PIXEL" -co
"TILED=YES" -co "PROFILE=GeoTIFF" img27-2.tif tmpfile.tif
mv tmpfile.tif img27-2.tif
gdaladdo -r average img27-2.tif 2 4 6 8 10 12 16
The results of the gdal-info now show:
Size is 1436, 3083
Coordinate System is:
PROJCS["GDA94 / MGA zone 56",
GEOGCS["GDA94",
DATUM["Geocentric_Datum_of_Australia_1994",
SPHEROID["GRS 1980",6378137,298.2572221010042,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6283"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4283"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",153],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",10000000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","28356"]]
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Left ( 428440.494, 7242335.760) (152d17'28.52"E, 24d55'57.13"S)
Lower Left ( 428440.494, 7241873.310) (152d17'28.43"E, 24d56'12.17"S)
Upper Right ( 428655.894, 7242335.760) (152d17'36.20"E, 24d55'57.17"S)
Lower Right ( 428655.894, 7241873.310) (152d17'36.11"E, 24d56'12.20"S)
Center ( 428548.194, 7242104.535) (152d17'32.31"E, 24d56'4.67"S)
Overviews: 718x1542, 359x771, 240x514, 180x386, 144x309, 120x257, 90x193
and the GenaMap results:
Format : tiff
Size : 1436 x 3083
Compression : none
I then use tiffsplit to split out the overviews for checking and converted
them to jpegs for the purposes of display.
As you can see the 2nd last overview (xaag.jpg) isn't complete and the last
overview (xaah.jpg) has the yellow at the bottom of the image. I get the
same results even if I drop the number of overviews to 4 (2 4 8 16).
This problem isn't just related to this image, it is visible in all 100 tiles
of my mosaic. Could this be due to a problem with my source images? The
source images are viewable ok through gimp/mapserver and all other image
viewers. I can make the source image availabe if needs be.
Any info and advice would be greatly appreciated.
Regards
Steve
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051014/055d5cd6/xaag.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051014/055d5cd6/xaah.jpg
