[Gdal-dev] error in compiling gdal on windows xp (gifdataset.cpp)
skotea at gmail.com
skotea at gmail.com
Fri Oct 14 11:55:07 EDT 2005
hi people,
i try to compile gdal (gdal-cvs-2005.10.11) on windows xp using
Microsoft Visual C++ Toolkit 2003 and Microsoft Platform SDK...
in fact i need to modify ogr2ogr to output a sort of xml file used by
a PocketPC software using a shp file as input. that's why i was
thinking about modifying kml output option a little...
my 1st test is to see if i can compile gdal original source before
modifying anything...
but i get these errors :
C:\TEST\gdal-cvs-2005.10.11\frmts>cd gif && nmake /NOLOGO /f makefile.vc &&
cd ..
cl /nologo /MD /GX /Zi /Fd..\..\gdal.pdb -I..\..\port -I..\..\ogr -I..\.
.\gcore -I..\..\alg -Ilibungif /c gifdataset.cpp
gifdataset.cpp
gifdataset.cpp(122) : error C2375: 'EGifOpen' : redefinition; different linkage
libungif\gif_lib.h(119) : see declaration of 'EGifOpen'
gifdataset.cpp(580) : error C2440: '=' : cannot convert from 'GifFileType *(__cd
ecl *)(void *,OutputFunc)' to 'GifFileType *'
There is no context in which this conversion is possible
gifdataset.cpp(580) : error C3861: 'EGifOpen': identifier not found, even with a
rgument-dependent lookup
NMAKE : fatal error U1077: 'cl' : return code '0x2'
Stop.
can someone help ?
thanks a lot
skotea
