[Gdal-dev] error in compiling gdal on windows xp (gifdataset.cpp)
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 14 14:44:40 EDT 2005
On 10/14/05, skotea at gmail.com <skotea at gmail.com> wrote:
> ecl *)(void *,OutputFunc)' to 'GifFileType *'
> There is no context in which this conversion is possible
> gifdataset.cpp(580) : error C3861: 'EGifOpen': identifier not found, even with a
> rgument-dependent lookup
> NMAKE : fatal error U1077: 'cl' : return code '0x2'
> Stop.
> can someone help ?
Skotea,
Either grab a newer CVS snap, or hand edit gifdataset.cpp and
remove the CPL_DLL in the declaration of EGifOpen().
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
