[Gdal-dev] ECW not building in
Charlton Purvis cplist at earthlink.net
Mon Oct 17 14:33:58 EDT 2005
Hi, Frank and everyone:
I followed a post you made earlier, Frank
(http://lists.maptools.org/pipermail/gdal-dev/2005-June/005949.html) to
build ECW as a supported GDAL format.  Many thanks for those pointers;
otherwise, I would never have gotten this far.  Everything built fine, but
gdalconfig --formats does not list ECW as a supported format.
Running the ./configure --with-ecw does give me the usual:
  JASPER support:            no
  ECW support:               yes
  MrSID support:             no
The ./make & ./make install work great.  But it doesn't show back up in the
final format list.
Do you have any ideas?
Thanks,
Charlton
