[Gdal-dev] ECW not building in
Mon Oct 17 16:00:13 EDT 2005
On 10/17/05, Charlton Purvis <cplist at earthlink.net> wrote:
> Hi, Frank and everyone:
> I followed a post you made earlier, Frank
> (http://lists.maptools.org/pipermail/gdal-dev/2005-June/005949.html) to
> build ECW as a supported GDAL format.  Many thanks for those pointers;
> otherwise, I would never have gotten this far.  Everything built fine, but
> gdalconfig --formats does not list ECW as a supported format.
> Running the ./configure --with-ecw does give me the usual:
>   JASPER support:            no
>   ECW support:               yes
>   MrSID support:             no
> The ./make & ./make install work great.  But it doesn't show back up in the
> final format list.
Charlton,
Try and "make clean; make; make install" and see if that helps.
Re-configuring does not always cause all the required files to get
rebuilt.
Best regards,
