[Gdal-dev] ECW not building in
Armin Burger
armin.burger at gmx.net
Mon Oct 17 17:04:15 EDT 2005
Charlton
I don't know if that's an option for you, but I asked the ER Mapper
development support and got the download link for the SDK 3.3 beta. It
just compiled under Linux without any modification using configure -
make - make install. In GDAL I used --with-ecw=/usr/local and
everything worked fine.
Also all problems we had with some datasets and an older ECW version
seem to have disappeared and the speed looks quite good. Mapserver
processes a 3 GB ECW on a 3GHz Pentium in about 1 s or less, independend
of the scale level. So I think the latest beta is worth trying it.
Armin
Charlton Purvis wrote:
> Hi, Frank and everyone:
> I followed a post you made earlier, Frank
> (http://lists.maptools.org/pipermail/gdal-dev/2005-June/005949.html) to
> build ECW as a supported GDAL format. Many thanks for those pointers;
> otherwise, I would never have gotten this far. Everything built fine, but
> gdalconfig --formats does not list ECW as a supported format.
> Running the ./configure --with-ecw does give me the usual:
> JASPER support: no
> ECW support: yes
> MrSID support: no
> The ./make & ./make install work great. But it doesn't show back up in the
> final format list.
> Do you have any ideas?
> Thanks,
> Charlton
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
