[Gdal-dev] Re: OGR PostgreSQL and schema
Charlie Savage cfis at interserv.com
Tue Oct 18 18:29:57 EDT 2005
Yes and no.  You don't "connect" to a schema - you connect to a
database.  You then reference tables in a schema like this:
"schema.table" - however, OGR does not support this.
As can work around this by setting the postgresql search_path to include
your schema.  You have to do it for the user, as opposed to a session,
since OGR will create its own connection. So:
ALTER USER <user_name> SET search_path TO <schema_name>,"$user",public;
If you have the same table name in different schemas, with different
fields, then you'll have to exclude the other tables by setting the
search_path appropriately.
Thanks,
Charlie
Tamas Szekeres wrote:
> Hi list,
> Is it possible to create or connect to PostrgreSQL data existing in a schema
> other than public?
> Tamas Szekeres
