[Gdal-dev] ORA-12705: invalid or unknown NLS parameter value
specified
Bart van den Eijnden
BEN at Syncera-ITSolutions.NL
Wed Oct 19 09:18:45 EDT 2005
Hi list,
just reporting this back in case anybody in the future runs into this.
When using ogr2ogr or ogrinfo on an OCI datasource I was getting:
D:\test>ogrinfo OCI:system/oracle at PORCL
ERROR 1: ORA-12705: invalid or unknown NLS parameter value specified
in <unnamed>
in <unnamed>
FAILURE:
I got the NLS_LANG setting from the database using the following SQL:
SELECT name,value$ from sys.props$ where name like '%NLS_LANG%';
and then used an environment variable before calling ogrinfo:
D:\test>set NLS_LANG=AMERICAN
INFO: Open of `OCI:system/oracle at PORCL'
using driver `OCI' successful.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
