[Gdal-dev] gdal-grass plugin
Markus Neteler neteler at itc.it
Wed Oct 19 12:06:14 EDT 2005
On Wed, Oct 19, 2005 at 11:53:17AM -0400, Frank Warmerdam wrote:
> On 10/19/05, Markus Neteler <neteler at itc.it> wrote:
> > Frank,
> > sorry, but IMHO you didn't run 'autoconf':
> > g++ -shared  ogrgrassdriver.o ogrgrassdatasource.o ogrgrasslayer.o -L/ssi0/ssi/neteler/grass61/dist.i686-pc-linux-gnu//lib -lgrass_I -lgrass_vask -lgrass_gmath -lgrass_gis -lgrass_datetime -lgrass_gproj -L/usr/local/lib -lgdal  -o ogr_GRASS.so
> > The link to -lgrass_vect is still missing... It's present in configure.in, though,
> > as submitted.
> > Please re-created it again,
> Markus,
> Doh!  You are right of course.  I have run autoconf, and reupdated
> the download site.  Let me know if this version doesn't work properly.
Frank,
tested, looks good!
Thanks again for merging the GRASS raster and vector plugins
(and to Radim as well)!
 Markus
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
