[Gdal-dev] Problem building for Solaris w/Oracle driver
Tom Canales
canales1 at llnl.gov
Wed Oct 19 19:54:41 EDT 2005
I've having problems building GDAL with the oracle driver.
Environment:
GDAL: v 1.3.1
OS: Solaris 2.8
Oracle: 10.2.0
As per the build instructions I ran:
> configure --with-oci=/oracle/product/10.2.0/db_1
then
> gmake install
everything compiled fine but I got the following linking error:
ld: fatal: file /oracle/product/10.2.0/db_1/lib/libclntsh.so: wrong ELF
class: ELFCLASS64
ld: fatal: File processing errors. No output written to .libs/libgdal.so.1.9.0
collect2: ld returned 1 exit status
gmake[1]: *** [libgdal.la] Error 1
gmake[1]: Leaving directory `/usr/local/gdal-1.3.1'
gmake: *** [check-lib] Error 2
Any help would be appreciated,
