[Gdal-dev] Problem building with static libproj4
Eric Dönges eric.doenges at gmx.net
Thu Oct 20 02:52:41 EDT 2005
I've encountered a problem when trying to build CVS GDAL using
'--with-static-proj4=<path to proj4 4.4.9 build directory>'. It seems
that a recent change
to the configure script has GDAL looking for libproj in <path
specified to option>/src
instead of <path specified to option>/src/.libs, where libproj4
(version 4.4.9) actually
builds the static library. Editing the configure script to use the
correct path is
simple enough, but I'm wondering if that is the correct solution.
With kind regards,
Eric
