[Gdal-dev] ORA-13199 when having a prj file
Ethan Alpert
ealpert at digitalglobe.com
Fri Oct 21 13:01:55 EDT 2005
Not sure this is a GDAL problem:
http://www.error-code.org.uk/view.asp?cl=ORACLE&p=ORA&ec=13139
The error code says to contact oracle support.
-e
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Bart van den
Eijnden
Sent: Friday, October 21, 2005 10:40 AM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] ORA-13199 when having a prj file
Hi list,
when loading a shapefile with a prj file I got the following error when
using ogr2ogr (GDAL 1.3.1) on an Oracle 10g R2 database (deleting the
prj file solved the issue):
C:\Program Files\gdal>ogr2ogr -update -f "OCI" OCI:system/psv9570 at PORCL
adrloc.shp
ERROR 1: ORA-13199:
ORA-06512: at "MDSYS.MD", line 1723
ORA-06512: at "MDSYS.MDERR", line 8
ORA-06512: at "MDSYS.CS_SRS_TRIGGER", line 2
ORA-04088: error during execution of trigger 'MDSYS.CS_SRS_TRIGGER' in
INSERT INTO MDSYS.CS_SRS (SRID, WKTEXT, CS_NAME) VALUES
(1000000124,'PROJCS
["unnamed",GEOGCS["unnamed",DATUM["Amersfoort",SPHEROID["Bessel -
1841",6377397.
155,299.152812825426]],PRIMEM["Greenwich",0],UNIT["Decimal
Degree",0.01745329251
99433]],PROJECTION["Stereographic"],PARAMETER["latitude_of_origin",52.15
6160556]
,PARAMETER["central_meridian",5.387638889],PARAMETER["scale_factor",0.99
99079],P
ARAMETER["false_easting",155000],PARAMETER["false_northing",463000],UNIT
["METER"
,1]]', 'unnamed' )
Best regards,
Bart
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
