[Gdal-dev] Double question: Spheres and Ellipsoids, Central Latitude
Bobby Kennedy kennedy at vrco.com
Fri Oct 21 15:49:37 EDT 2005
Hello all,
Two questions, just figured I'd roll it into one email....  The little
main() below illustrates both questions (I'm using gdal 1.2.3, and proj
4.4.8).
1) With regards to proj.4 and the projections that only support
spherical solutions (e.g. Equirectangular), I saw the recent post "eqc
warping problem" where you mention a possible work around for the z
changes, do you have plans on implementing that?  Or even better, do you
know if there are plans to add support for ellipsoids to the these
projections (it's mentioned on the proj.4 site under 'Future plans', any
idea of the time frame)?
2) Second question is regarding the code below and the central latitude
for my equirectangular projection. It doesn't seem to be having any
effect.  As can be seen in the code, I do a:
OSRSetEquirectangular(ecWGS84, 30, 110, 0, 0).  When I convert the
geographic point (110,30,0), I would expect to see a output point of
(0,0,whatever), but the Y is not 0, instead it appears to the meter
location of the 30 deg lat.  Is this a fixed bug and I'm just out of
date, or something else?  Any ideas?
Thanks a lot,
  Bobby
#include "ogr_srs_api.h"
#include <stdio.h>
int main(int argc, char**argv)
  // Create a geographic WGS84 srf
  OGRSpatialReferenceH gdWGS84 = OSRNewSpatialReference(NULL);
  OSRSetWellKnownGeogCS(gdWGS84, "WGS84");
  // Create a EC WGS84 srf
  OGRSpatialReferenceH ecWGS84 = OSRNewSpatialReference(NULL);
  OSRSetProjCS( ecWGS84, "EC (WGS84)." );
  OSRSetEquirectangular(ecWGS84, 30, 110, 0, 0);
  OSRSetWellKnownGeogCS(ecWGS84, "WGS84");
  // Create a coordinate transformation form GD to EC
  OGRCoordinateTransformationH gd2ec;
  gd2ec = OCTNewCoordinateTransformation(gdWGS84, ecWGS84);
  // Setup a coord
  double x = 110;
  double y = 30;
  double z = 0.000000;
  // Convert form GD to EC
  OCTTransform(gd2ec, 1, &x, &y, &z);
  // Survey says...
  // x = 0.00000000000000000
  // y = 3321065.1468621432    (should be 0???)
  // z = -5312.5797059889883   (Expected b/c EC only supports spherical)
  return 0;
Bobby Kennedy
Software Engineer
VRCO, Inc.
757-456-5500
