[Gdal-dev] Re: ECW JPEG 2000 Source SDK v3.3 (RC)
Garrett Potts
potts at cfl.rr.com
Tue Oct 25 14:36:46 EDT 2005
Hello All:
To build it on MACOSX 10.4.2 g++ version 4.0.0 I had to make one
small change in the file:
NCSSocket.cpp
CNCSSocket::CNCSSocket(const int handle)
: m_handle(handle), m_connected(true)
//init();
struct sockaddr_in info;
#if defined(POSIX) && !defined(HPUX)
# ifdef MACOSX
socklen_t tempSize = sizeof(struct sockaddr);
//int tempSize = sizeof(struct sockaddr);
# else
# endif
#else
#endif
getpeername(handle, (struct sockaddr*)&info, &tempSize);
m_connectedPort = info.sin_port;
//m_connectedTo = inet_ntoa(info.sin_addr);
#endif
On my MAC I had to set int tempSize = sizeof(struct sockaddr);
to
socklen_temt pSize = sizeof(struct sockaddr);
Has any one else had the same problem with 10.4.2?
This was the only modification and it built. Not tested with GDAL
yet though.
Take care
Garrettt
