[Gdal-dev] Read/Write Oracle Spatial
Hallgren Johan E jhhal at wmdata.com
Fri Oct 28 10:11:41 EDT 2005
Silly questions...
You are mention that you have committed a change in
CVS, you are also asking me to do some tests on that. I would be glad to
do it but where can a get the source. With CVS do you mean
http://cvs.maptools.org/query.cgi? Can I get some source code to
recompile there?
/Johan
-----Original Message-----
From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On Behalf Of
Frank Warmerdam
Sent: den 27 oktober 2005 14:44
To: Hallgren Johan E
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Read/Write Oracle Spatial
On 10/27/05, Hallgren Johan E <jhhal at wmdata.com> wrote:
> Thanks for all the assistance.
> My SetFeature problem was probably caused by the bad geometry handling
in the code. It's solved now but there is still two functions a have
isolated but problems remain.
Johan,
Excellent.
> When updating a field I use a function SetField and it just don't
work. It will crash on that call.
I suspect this problem is a C# swig binding issue.  You should
likely file a bug on it.
> The other function is DeleteFeature. The problem is the same, it just
don't work and crash on that call.
I have reviewed the code and I see there is no implementation
of DeleteFeature() for the OCI driver.  I have committed one in
CVS and would appreciate it if you could test it.  I should add
I haven't been able to even try compiling it since I am not booted
into the system with oracle at this time.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
