[Gdal-dev] MrSID SDK -> GeoExpress SDK
Bart van den Eijnden
bartvde at xs4all.nl
Fri Oct 28 12:25:09 EDT 2005
Okay, found the answer in this fwtools e-mail:
http://lists.maptools.org/pipermail/fwtools/2005-June/000106.html
This MrSID stuff is confusing though :-)
Best regards,
Bart
Bart van den Eijnden wrote:
> Hi Frank,
> thanks for the confirmation.
> Is it one SDK for both reading and writing? Are there any limits to
> writing?
> Best regards,
> Bart
> Frank Warmerdam wrote:
>> On 10/28/05, Bart van den Eijnden <bartvde at xs4all.nl> wrote:
>>> Hi list,
>>> can anybody confirm that the MrSID SDK is now called "GeoExpress SDK"?
>>> Is this the SDK one needs to use MrSID in combination with GDAL?
>> Bart,
>> Yes, it is called the GeoExpress SDK now (perhaps it always was).
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
