[Gdal-dev] How can I get coordinate system and projection from
shape files?
Frank Warmerdam
warmerdam at pobox.com
Mon Oct 31 10:03:01 EST 2005
On 10/31/05, lky <moon_inwell at 163.com> wrote:
> Hello,everyone:
> I'm a new learner of the gdal. During my study, I met some problems. I hope
> I can find help here.
> I found these is one sentence "If a .prj files in old Arc/Info style or new
> ESRI OGC WKT style is present, it will be read and used to associate a
> projection with features." in \ogr\dev_shapefile.html.
> And I found there are some *.prj files with the same name shapefile in
> directory C:\arcgis\arcexe83\Reference Systems(The directory which I install
> arcinfo).In the ArcMap, that the frame map file is *.mxt.
> I try to use the OGRSFDriverRegistrar::Open function to open these *.prj
> files but I failed.
> So I have the following questions.
> 1. Who can explain the use of these *.prj files in this directory? Which
> shapefiles do they support? Or they only support project mode for AcrMap?
Kunyang Li,
You should open the shapefile normally with OGRSFDriverRegistrar::Open()
and then fetch the layers from the datasource. To find the coordinate
system of a layer you can call OGRLayer::GetSpatialRef() to get a handle
to the corresponding OGRSpatialReference object.
This method will read it from a correspondingly named .prj file if it
is present.
> 2. What is the relation with the *.prj and *mxt files?
I don't know anything about mxt files.
> 3. How can I read the coordinate system and projection from the *.prj files?
> And whether this prj file support the coordinate system and projection for
> the same name shapefile or for the shapefiles in the same directory?
OGR assumes a .prj file applies to the shapefile with the same
base filename. If there is no corresponding .prj file, then GetSpatialRef()
will return NULL.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
