[Gdal-dev] Accessing polygon data through the scripting interface
Ari Jolma
ari.jolma at tkk.fi
Mon Sep 5 02:00:54 EDT 2005
Hello,
I saw some discussion on this subject earlier on this list
(http://lists.maptools.org/pipermail/gdal-dev/2005-February/005109.html)
but I think it's still impossible(?) to access the polygon data (rings
and then vertices) through the scripting interface.
I see that the OO interface for scripting languages is done using the C
(not C++) api (ogr_api.h etc). The interface is rewritten into C++ in
ogr.i but without subclasses of OGRGeometry like OGRPolygon. Some of the
subclass methods are written into the C API but not all. Shouldn't also
the OGRPolygon methods Get*Ring be wrapped into OGRGeometry? In fact I
tried this and with these in place one is able to do things like this
(in Perl but the small changes I had to make were not Perl specific):
$geom = $feature->GetGeometryRef();
$ring = $geom->GetExteriorRing(); # assuming geom is polygon...
$ring->GetX(10);
Methods GetPoint(int) and GetPoints would be useful also.
These may be implemented in ogr_api.cpp (then they are available in the
C interface) or in ogr.i. GetPoint(int) is in ogr_api.cpp but not in ogr.i.
Ari
