[Gdal-dev] Bogus OGRSpatialReference should cause error, right?
Frank Warmerdam fwarmerdam at gmail.com
Mon Sep 5 16:46:12 EDT 2005
On 9/5/05, Ben Discoe <ben at vterrain.org> wrote:
> I spent a bit of time this evening tracking down a problem with
> OGRSpatialReference objects.  It turns out that
> OGRCreateCoordinateTransformation will accept them even when they contain no
> CRS at all, i.e. poRoot=NULL.  It would have shortened my debugging time if
> OGRCreateCoordinateTransformation had returned an error and refused to
> transform.  Instead, it returns a bogus transform which gives strange
> results.
Ben,
I concur.  I have tightened up error checking in the exportToProj4()
and OGRProj4CT::Initialize() methods.
Best regards,
