[Gdal-dev] downsampling shapefiles ?
Chapman, Martin
MChapman at sanz.com
Sat Sep 10 00:53:43 EDT 2005
I agree. It would be nice to be able to render fewer points when my map
is zoomed way out. I think arcmap does that kind of thing. How does a
geometry simplification algorithm work? Does it look for linear
patterns in the geometry and then somehow eliminate points based on some
sort of angle/distance tolerance?
Martin
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank
Warmerdam
Sent: Friday, September 09, 2005 8:16 PM
To: Christian G. Tveen
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] downsampling shapefiles ?
On 9/9/05, Christian G. Tveen <cgt at navicon.dk> wrote:
> Hi,
> I have a number of very fine grained shape files. Is it possible to
> have gdal in some way downsample these files to be more usable for
> overview purposes ?
Christian,
No, there is no support for geometric simplification in OGR. I just
checked GEOS's API documentation and I don't see anything there either.
I think I have heard there is something in PostGIS for generalization
but I didn't check into it.
I do think a "textbook" geometry simplification algorithm would be an
asset to GEOS, and I would be willing to expose it in some fashion
through ogr if it were available.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
