[Gdal-dev] Testing creating and opening raster datasets
Frank Warmerdam
fwarmerdam at gmail.com
Tue Sep 13 21:16:33 EDT 2005
On 9/13/05, Ari Jolma <ari.jolma at tkk.fi> wrote:
> - What does the "unsupported combination.." mean and how to detect it
> before creating a dataset?
Ari,
There are cases where particular combinations of pixel
data type and band number are not supported. However,
in the NITF driver case, I think I just never implemented proper
creation support for complex data types. I have removed these
from the format list till I have time to implement and test them
properly.
> - ENVI hdr reports that it can create "UInt32Float32" datatypes, this is
> a bug in envidataset.cpp:1375.
Fixed.
> - Atlantis MFF2 (HKV) Raster announces that it can create datasets of
> more types than it actually can.
I'll leave this to Gillian to address.
> - It takes a bit of guessing (I hard coded that into the test script)
> what filename to give to the Open function to make it succeed. Is the
> extension available somewhere in the metadata? (sorry, too lazy to look
> now).
Where there is a clearly preferred extension for a format,
it is set in the driver metadata like this:
poDriver->SetMetadataItem( GDAL_DMD_EXTENSION, "ntf" );
For some formats there is no obvious preferred extension. In some
cases it may just be that there is no metadata definition of it when
there ought to be.
I would add that while I try to declare enough information in the
driver metadata to allow deciding what options are supported by
what formats, I have not been completely successful. To some
extent the user still ends up having to read the format docs for
odd situations.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
