[Gdal-dev] mingw build, MSVCR71.DLL problem
Pete Nagy
Peter.Nagy at vexcel.com
Fri Sep 23 19:12:01 EDT 2005
Thanks to those who sent me replies on this. As Frank said this has to do
with how the python binaries were built, and for anyone needing help with
this type of problem there is some discussion at:
http://jove.prohosting.com/iwave/ipython/issues.html
-> Pete
Pete Nagy tel: (303) 583-0248
Vexcel Corporation fax: (303) 583-0246
http://www.vexcel.com home: (303) 823-2336
On Thu, 22 Sep 2005, Frank Warmerdam wrote:
> On 9/22/05, Pete Nagy <Peter.Nagy at vexcel.com> wrote:
> > My question is, can anyone explain the use of msvcr71.dll with gdal?
> > This is a newer dependency; I just needed to grab it when I went to 1.2.6.
> > Why is it needed instead of msvcrt.dll? Any ideas why the gdal.dll does
> > not have this dependency, and the python module does? Any ideas of
> > workarounds?
> Peter,
> My understanding is that MSVCR71.DLL is what is used by
> Visual Studio.NET built applications and that Python 2.4 binaries
> are now normally built this way. Is it possible that switching to Python
> 2.4 actually introduced this requirement?
> I don't know a good solution, though switching back to Python 2.3
> would likely help.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
