[Gdal-dev] Error compiling gdal against mrsid dsdk on solaris
H.Porath at hzd.hessen.de H.Porath at hzd.hessen.de
Thu Apr 13 10:17:39 EDT 2006
Hi Julien,
thanks for the hint, but unfortunately it did not work. We got the same error. Do you have other ideas regarding compile flags? Why do you know how MrSID SDK was compiled? Is there a documentation?
Regards,
Holger
-----Ursprüngliche Nachricht-----
Von: Julien Demaria [mailto:dem at acri-st.fr]
Gesendet: Mittwoch, 12. April 2006 18:08
An: Porath, Holger (HZD)
Cc: gdal-dev at lists.maptools.org
Betreff: Re: [Gdal-dev] Error compiling gdal against mrsid dsdk on solaris
I believe you have a PIC problem, you should add the -fPIC flag to gcc
for compiling all your .c and .cpp, because MrSID SDK is compiled with
-fPIC.
Regards,
Julien
