[Gdal-dev] OGR Georeference
Frank Warmerdam
warmerdam at pobox.com
Wed Apr 19 16:09:37 EDT 2006
Rob McCulley wrote:
> I finally managed to talk to the data provider. It is a "local"
> coordinate system per file. It looks like I need to warp each file.
> Any way to do this using ogr?
Rob,
There isn't any canned approach to this in OGR. You could write a
customized version of ogr2ogr that applies your transformation likely
using the GDALGCPTransformer for mapping between your local coordinate
system and a projected coordinate system. In theory you could also
implement a python script to do this, but then you would be on your own
to do the actual transformation calculation. If you wanted to take that
approach you could look at:
http://www.gdal.org/srctree/pymod/samples/vec_tr.py
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
