[Gdal-dev] OGR Georeference
Matthew Perry
perrygeo at gmail.com
Wed Apr 19 20:58:01 EDT 2006
On 4/19/06, Rob McCulley <RMcCulley at county24.com> wrote:
> I finally managed to talk to the data provider. It is a "local" coordinate system per file. It looks like I need to warp each file. Any way to do this using ogr?
Another possibility, if you have a layer in the "proper" coordinate
system to which you could match ground control points, is to use the
Warping tool in OpenJump ( http://openjump.org/ ). It allows you to
graphically create warping vectors between control points and apply an
affine transformation.
Matt Perry
http://www.perrygeo.net
