[Gdal-dev] writing to GRID
Prosperi, Paolo (SDRN)
Paolo.Prosperi at fao.org
Thu Apr 20 04:20:39 EDT 2006
Hi all.
I'm a newbie of GDAL and surely NOT a programmer.
The standard executable of GDAL 1.3.1 works smoothly on my windows 2000
platform until I try to write to esri grid formats.
In particular, when I use the command gdal_merge and the AAIGrid output
format:
gdal_merge -o my-path\my-grid -of AAIGrid -n 0 my-image1 my-image2
I get as error:
ERROR 6: GDALDriver::Create() ... no create method implemented for this
format.
File "C:\Programs\FWTools\bin\gdal_merge.py", line 450, in ?
t_fh.SetGeoTransform( geotransform )
AttributeError: 'NoneType' object has no attribute 'SetGeoTransform'
Instead, if I try to use the GIO driver:
gdal_merge -o %path%\my-image -of GIO -n 0 my-image1 my-image2
I simply get:
Format driver GIO not found, pick a supported driver.
The question is:
given I haven't got a clue on how to compile GDAL from source, is anybody so
kind to pass me a windows executable version of GDAL with working GIO/AAIGrid
driver?
Dummy-like directions (or links to appropriate web sites) on how to compile
would also do and be very much appreciated.
Thanks very much,
Paolo P.
