[Gdal-dev] building gdal on solaris
Peter.Rushforth at statcan.ca
Fri Apr 21 10:39:37 EDT 2006
Hi Frank,
I did previously try with 1.3.2b1, here's what I get:
bilbo{rushpet}53: pwd
/bilbo05/rushpet/gdal/gdal-1.3.2b1
bilbo{rushpet}54: make
(cd port; make)
make[1]: Entering directory `/bilbo05/rushpet/gdal/gdal-1.3.2b1/port'
g++ -Wall -fPIC -O2 -DOGR_ENABLED -I/bilbo05/rushpet/gdal/gdal-1.3.2b1/port -c -o cpl_strtod.o cpl_strtod.cpp
cpl_strtod.cpp: In function `float CPLStrtofDelim(const char*, char**, char)':
cpl_strtod.cpp:719: error: `copysignf' undeclared (first use this function)
cpl_strtod.cpp:719: error: (Each undeclared identifier is reported only once for each function it appears in.)
make[1]: *** [cpl_strtod.o] Error 1
make[1]: Leaving directory `/bilbo05/rushpet/gdal/gdal-1.3.2b1/port'
make: *** [port-target] Error 2
I'm still determined to get it running - it seems others have done
so!
Cheers,
Peter
Name: Peter Rushforth (Peter.Rushforth at statcan.ca).vcf
Type: text/x-vcard
Desc: Peter Rushforth (Peter.Rushforth at statcan.ca).vcf
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060421/0331fbb4/PeterRushforthPeter.Rushforthstatcan.ca.vcf
